I am really having trouble with motor mounts for a 1964 small block, the first ones came from Corvette Central and were 1 5/8 thick, way to small, the second set came from Napa, they are 1 3/4 thick and this is the same as the original ones I took off, but upon installing them I am still short of getting the bolts in by more than 1/2 inch, I have tried doing each side moving the frame around and can not get them to work, I am considering making some shims for both sides to bring the mounts inward so the bolts will go through, anyone got any suggestions?
Mike
Mike
