Guys,
I have just completed a body off chassis restoration and reinstalled the body with new solid body mounts and the same number of shims as it came off. I installed a rebuilt rear 9 leaf spring (removed from a 69 Corvette, blasted the steel and repainted the parts. New rubber separators were also installed. When I bought the car it had a composite spring on it, so I removed it and used a factory rear spring. Problem is the rear end appears jacked up and the clearance from the top of the tires to the wheel well lip is way up. I see no installation errors. Is this a condition that after some use will tend to settle out? I've read about this issue, but I don't see this coming down that much. Everything is new or rebuilt thruout the entire chassis. I was hoping someone might have some experience with this. On my other 69, the spring was removed and rebuilt the same way but it did not jack up the rear end. HELP????
Brad
Brad
