Need Info from our Mid 90's Corvette Experts on Electrical Connectors - NCRS Discussion Boards
  • Larry E.
    • 1692
    Just got done from draining old gas out of a 94 Camaro LT1. Had to run the fuel pump
    w/o engine running. This can be done with the "fuel pump prime connector". Had to use
    small alligator clip which did not work to well. Below is a picture of the connector and
    I guessing the Corvettes had a similar setup. Does anybody know anything about this
    GM connector? It looks to be some type of small spade connector. Does Kent-Moore
    or anybody else have a test lead that would hook-up to this connector? Have never seen
    one like this. Any Idea's? Please Comment. Larry
    Larry
    LT1 in a 1LE -- One of 134
    • 15616
    Re: Need Info from our Mid 90's Corvette Experts on Electrical Connectors
    Calling Bill Clupper.
    I will also give you a chance to the top.
    • Mike E.
      • June 24, 2012
      • 920
      I would be real careful running an F-Body fuel pump low on fuel. I had an LT-1 Firebird and I ran out of gas (Don't Ask) and it burned up tank pump. They use the fuel to cool the pump, it's was a real pain to change the pump on those too.
      Mike
      • Larry E.
        • 1692
        Mike
        Mike: So noted; this was discussed in a previous thread on the subject.--Larry
        Larry
          • 43248
          Larry------
          Based on what I can see of it in your photos, I believe the connector is a GM #12101850 also known as Delco #PT242.
          • Larry E.
            • 1692
            Larry------
            Joe: I think you hit the nail on the head again; thanks! But how would I find the "Male" counterpart that would fit this connector??
            Larry
            Larry
            • Larry E.
              • 1692
              Update:
              Joe: Just found this through google. Would Delco#PT220 GM#12101828 be the male counterpart for the above?? Larry
              Larry
                • 43248
                Update:
                Larry-----
                As a matter of fact, GM #12101828, aka Delco #PT 220, is the only available connector that MIGHT work with the 12101850. I'm not sure that it will, but it's the only one that might.
                I can find no Kent-Moore tool for this application. That's surprising since I would think that this connector, being part of the harness, would necessarily result in there being a tool for use with it. Doesn't the Camaro factory service manual speak to this?
                • Larry E.
                  • 1692
                  Larry-----
                  Joe: Went through the Service Manual and no mention of the connector. It does show it in one of their illustrations; but no detail. Thanks Much-Larry
                  P.S. I think you and I and my cat is the only ones up at this hour!! Ha Ha
                  Larry
