63 Rear emblem issue... - NCRS Discussion Boards
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12734
    I wanted to mount my original rear emblem but I noticed the studs were too thin for the regular speed nuts in the set (or too thick for the speed nuts with the really tiny holes). Is this a common issue. Where can I get the correct speed nuts?
    Rob.
    NCRS Software Developer
  • Alan D.
    • January 1, 2005
    • 2038
    Re: 63 Rear emblem issue...
    Those studs SB 1/8 " (that's an from a 64 car, pn 3797414) Only think 63 were the same.
    • Rob M.
      NCRS IT Developer
      • January 1, 2004
      • 12734
      I have a late '63, might be the same. Is anyone shipping the right speednuts for that emblem?
      Rob.
      • Wayne W.
        • April 30, 1982
        • 3605
        Originals had the little push in retainers. Barrel Clips.
        • Wayne W.
          • April 30, 1982
          • 3605
          To clarify my last post. 63s had the barrel clips, however, I cant say they all did. I don't know if it was an early thing, or a late thing, or if most had clips or pal nuts, just that some had the clips.
          • Dick W.
            • 10483
            AKA barrel nuts or tubular nuts
            Dick Whittington
            • Timothy B.
              • April 30, 1983
              • 5183
              Are these retainers similar to what holds the heater cable to lever.
              • Dick W.
                • 10483
                . No, the retainers you are talking about are barrel nuts. Tubular nuts push in the hold and then the emblem studs push into the nots. Everything is retained by friction
                Dick Whittington
                • Timothy B.
                  • April 30, 1983
                  • 5183
                  I am having a brain fart here so if anyone has a picture I would appreciate it. :-)
                  • Wayne W.
                    • April 30, 1982
                    • 3605
                    http://www.etrailer.com/Accessories-...n/60-0244.html
                    • Dick W.
                      • 10483
                      If your local auto parts store has an Auveco catalog, they are in it. They removed their online catalog
                      Dick Whittington
                      • Timothy B.
                        • April 30, 1983
                        • 5183
                        What's this clip push in from above and the emblem post set inside?
                        • Wayne W.
                          • April 30, 1982
                          • 3605
                          ....Yep....
                          • Timothy B.
                            • April 30, 1983
                            • 5183
                            Learn something new everyday..thanks Wayne and Dick.
                            • John D.
                              • December 1, 1979
                              • 5507
                              What is the point deduction for not having the Corvette script emblem fastened? Thanks, JD
