C1 leaf spring tip question - NCRS Discussion Boards
  • Keith R.
    • August 31, 2001
    • 671
    Got a leaf spring liner kit from Corvette Central and it has the stainless tip on the third (shortest) liner. Should I remove this tip prior to assembling the spring?
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
  • Troy P.
    • February 1, 1989
    • 1284
    Re: C1 leaf spring tip question
    All of the unrestored 53-55 cars I've inspected did not have that tip. That includes cars with as little mileage as 2331. I've also been under two 57 survivors and the photos I took show no tip on their short liner either.
    But I've heard the theory that for some reason as the spring flexes that tip gets pushed off.
    A good question I can't answer would be, "Why would it not have a tip like the others?"
    Obviously I did not answer your question. Hopefully the info I have provided eventually leads you to the answer.
    • Keith R.
      • August 31, 2001
      • 671
      Thanks for sharing your expertise and insight Troy. The JM says tips on only the two top liners so I will probably go with that.
      Keith MacRae
      NCRS #36692
      New Mexico Chapter
      1960 290HP FI
      • Joe M.
        • April 30, 1990
        • 1342
        I looked at 4 1960 Bow Tie cars at the National Convention and the short liner did not have a metal tip.
        • Keith R.
          • August 31, 2001
          • 671
          Thanks for that Joe. That confirms my thoughts. I will remove the tips from the short liner prior to banding.
          Keith MacRae
          NCRS #36692
          New Mexico Chapter
          1960 290HP FI
          • Joe M.
            • April 30, 1990
            • 1342
            If the clips are made like the original clips, they will have two rows of tiny teeth that bite into the liner. If present, the teeth will prevent you from pulling them off easily. You may have to use a cut off disk on a dremel tool and cut down the center of the length of the clip, then pull the two sides away from the liner. Good luck.
            • Troy P.
              • February 1, 1989
              • 1284
              Should be able to just pry them open and they'll slide off.
