63 front and rear exterior window trim removal - NCRS Discussion Boards
  • Robert B.
    • March 1, 1992
    • 265
    I was under the impression that there were clips that I needed to condend with,but as I began to under go the removal of the trim I found that there were NO clips on either the front or rear windows just a lot of goop.Is this typical. (Early 63)
  • Timothy B.
    • April 30, 1983
    • 5196
    Re: 63 front and rear exterior window trim removal
    Robert,
    There are clips, 18 thin clips and 6 thick clips in front and something like 9 on each rear window. These clips slip over the fiberglass and have a hook type extension that locks on the molding. Like I mentioned in another post, be careful with you moldings as they are hard to find and $$$$ to replace if you bend them.
    All one year only stuff.
    • Gary F.
      • August 29, 2010
      • 248
      • Robert B.
        • March 1, 1992
        • 265
        finally got exterior trim off the windows last night. After understanding how the clips worked it was not too difficult with exception of all the goop.I just used a putty knife ( good stiff blade) and something like a piece of 1/2 inch round wood dowel to help for a little leverage, like a pry bar if you will. Thanks To everyone for the help.
        • Alfred D.
          Infrequent User
          • June 28, 2012
          • 2
          hi gary will be doing the window removal soon this helps a lot. Al 1963 coupe
