midyear hardtop decklid dilemma - NCRS Discussion Boards
  • Craig O.
    • July 31, 1983
    • 207
    My car has the holes and hardware installed on the sides behind the seat, but no sign of holes ever been drilled in the rear decklid and I believe the decklid is original to the car. were all convertibles equipped with side hardware installed from the factory regardless of hardtop option? also is there any other way to tell if the car came with a hardtop, trim tag, protecto plate or other hardware that might be installed from factory?
    Re: midyear hardtop decklid dilemma
    Craig -
    No holes were drilled, either for the two rear hold-down bolts or for the two front/side attach bolts unless the car order specified a hardtop; those holes were drilled at St. Louis. If it's a '67 and you have the tank sticker, the C07 hardtop option will show there, or if it's any year midyear and you have a St. Louis body with other than a black interior, the trim ECL code on the trim tag will indicate a hardtop.
    • Gene M.
      • April 1, 1985
      • 4233
      Craig -
      Hey John,
      While we have your attention on this post, one question. On the AO Smith 67 cars delivered with a hardtop only, were the four mountings on the deck already there from AO Smith? (Possible assuming only the front latches retained the top). Or done at the St Louis plant? thanks
      • Wayne W.
        • April 30, 1982
        • 3605
        The tops were delivered from AOS on the vehicle, so the mountings would have been there.
          Originally posted by Gene Manno (8571)
          Hey John,
          As Wayne noted, A.O. Smith hardtop cars were delivered to St. Louis with the hardtop in place; this was true whether they were hardtop-only or 2-top cars. The link below will take you to an article that describes the A.O. Smith operation in detail, including exactly the state of completion of the bodies as-shipped to St. Louis.
          http://www.lbfun.com/warehouse/tech_.../A.O.Smith.pdf
          • Tim G.
            • March 1, 1990
            • 1417
            Great article, did they start building Shelby fiberglass components at the same plant later on?
              Tim -
              Yes, they did - the stock Mustangs were shipped in from Detroit and went on a disassembly/assembly line on the second floor of the plant where the stock pieces were removed and all the Shelby pieces were added to create the KR500 convertibles.
              • Tim G.
                • March 1, 1990
                • 1417
                Talk about ironic, building Corvettes one year and building Shelbys the next year.
