My 1964 327/365 Special Hi Performance (no A/C) water pump pulley cracked. It is pretty bad and I am not comfortable having it welded. I am looking to purchase a new one (they are getting hard to find). In reading archives, I understand a reinforcement spacer is now recommended on all applications even though mine did not have one from the factory. I found the spacer in my parts catalogs. My questions are;
1. Does the spacer go in front or behind the pulley..I think it goes behind which would seem to make it more solid?
2. If I install the spacer behind the pulley, I have read the water pump flange would need to be "pressed on" a little farther (the same thickness of the spacer) to accommodate the added spacer and still maintain pulley alignments. HOW do I press it on farther? Can I do this at home? Do I need a press or can I use a large socket and tap it with a hammer? Do I have to remove water pump to do this? Or do I have to take the car and or the pump to a shop with a press?
3. Does anyone know where I can buy the water pump pulley GM #3770245, 7 1/8" O.D. deep 2 groove?
4. What is a fair price?
Thanks in advance!!!
Tim
Tim
