53 and early 54 hood pull survey - NCRS Discussion Boards
  • John L.
    • February 1, 2005
    • 207
    Re: 53 and early 54 hood pull survey
    Troy,
    Just wanted to ask ...... is this flat plate bracket we are discussing only used on the drivers side and the passenger side hood pull cable does not???
    • Troy P.
      • February 1, 1989
      • 1284
      Yes, that is correct. The extension plate was only installed on the driver's side.
      • Chris S.
        • January 1, 2000
        • 1068
        Troy
        I have 1953 #201 here now
        FYI - the extension is riveted to the dash and the hood pull is screwed to the plate with philips headed screws
        If you need a photo - let me know
        I am going to tear this car down this week - so I will be taking alot of documentation photos
        Chris
        • Troy P.
          • February 1, 1989
          • 1284
          Thanks Chris. That's what I would expect to find.
          Only thing left to do is determine if very early 53s did not come with the riveted extension plate. Checking on car #18 now.
