Does a steering-gear change- out involve removing steering columnin a C2? - NCRS Discussion Boards
  • Nick P.
    • April 26, 2010
    • 8
    Thanks for your concern:
    Nick (51719)
    Does a steering-gear (box) change-out involve removing the steering column in a C2?
    • 6950
    Re: Does a steering-gear change- out involve removing steering columnin a C2?
    Nick, no need to remove the column, unbolt the rag joint at both ends and it will slide -up the column shaft. make sure to center the steering wheel also
      • 15706
      The procedure is in the shop manual. You do have one, yes?
