Help Estimating Tire Deduction - NCRS Discussion Boards
  • Ron N.
    • August 18, 2008
    • 243
    I've been getting a 75% (18 point) originality deduction for having correct size/correct WW, Michelin radials on my 67. What deduction can I expect with new repos of correct size & 5/8" WW?
    Would there be any difference in deduction between brands below:
    -Coker Firestone Firestone Deluxe Champion
    -Coker Goodrich Silvertown
    -Kelsey Goodyear Power Cushion
    Thanks Ron
  • Michael J.
    • January 27, 2009
    • 7167
    Re: Help Estimating Tire Deduction
    They are all the proper bias-ply OEM brands, but I think that only the Kelseys are nylon, IIRC the Cokers are polyester. Since the originals were nylon, then the Kelseys would have the lowest deductions. Probably 10% due to DOT marking but that is all?? Not sure if polyester would be the 20% or 30% deduct due to "slightly" or "considerably" different.
    • Bill W.
      • March 1, 1980
      • 2000
      Kelsey makes the closest tire ,they are made from the original molds and are the correct compound (nylon) with the correct 2 ply 4 ply rating . Cokers are polyester with a load range B rating . I just drove to there store (Kelsey) last week and and bought 5 775 15 Blackwalls for my 65.
      • Guest
        Judging Reference Manual (JRM) is your friend! It will explain the standard deductions for tires and many other items. I believe standard deduction for the tires you have described it THREE points for the four tires on the ground. But, don't hold me to that since I do NOT have the JRM with me here at work.
        • Jaime G.
          • April 1, 1988
          • 480
          Rick is correct on the deduction. Michael and Bill are correct regarding the Kelsey tires.
          • Ron N.
            • August 18, 2008
            • 243
            Thanks for responding and for the information. I have been told that the Kelsey GY Power Cushion were the most originals but didn't understand why. So, for my clarification, the Firestone and Goodrich by Coker were originally nylon but repos are now made with polyester.
            How do judges determine the material used or do they know Firestone and Goodrich repos where made with different material?
            Ron
            • Michael J.
              • January 27, 2009
              • 7167
              Ron
              My BFG Cokers say "Polyester Cord" right on the side of the tire.
              • Chris E.
                • November 3, 2006
                • 1336
                Ron, my car with the Kelsey sourced Goodyear Power Cushion 5/8" WW tires consistently gets a 3 point deduct at Regional and National events for originality. Other than finding an ORIGINAL set of tires, I would suggest buying from Kelsey. Great company, service and product. Highly recommended.
                Chris Enstrom
                2011 Z06, red/red
                • Kurt G.
                  • April 30, 2005
                  • 343
                  One addition. Unless I misunderstood, the Kelsey tires are actually made by Goodyear and licensed to Kelsey for sale. The Cokers are made by somebody that Coker contracts with to use the mold they have, which unfortunately are not always correct in configuration, i.e. tread pattern, sidewalls, cord, etc. Kelsey is the way to go IMHO.
                  Kurt Geis
                  Chairman, Midway USA Chapter
                  Targa Blue 1972, Top Flight and Duntov Award, 2014
                  Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
                  Arctic White 2013 60th Anniv Special Edition Conv.
