68 Door Panel Refurb?? - NCRS Discussion Boards
  • Dale C.
    • November 1, 1999
    • 844
    IMG_6859.jpgThere has been recent discussion about trying to bring back older original panels and I too am a fan of originality. So I'm thinking of redoing my old Feb original panels (for a Mar car). The CA ones on the car are in nice condition but don't fit as good as the original, gap at top. Question, does this left panel look beyond redemption? Other than this blemish they are in great shape. I have seen the up scale car dealer suggestions for repair but this has some vinyl missing. CA has a re-skin option but I sure would like to stay original, any thoughts? Dale
  • Lyndon S.
    • April 30, 1988
    • 1027
    Re: 68 Door Panel Refurb??
    I had my old door panels re skined years ago from CA and they did a very good job on them. I would do that if the substrate would be in good condition.
    • Patrick N.
      • March 10, 2008
      • 954
      image.jpgimage.jpgDale, my 68 door looks a lot like yours" I hope there is a good solution to be had. I'd like to keep my doors also. I was going to re-skin mine unless this can be repaired.
      BTW, sine both of our cars are March 68, I am curious if "Rose" did your door? Always neat to find that sort of thing.
      • Jim T.
        • March 1, 1993
        • 5351
        My 1968 was built in FEB and bought in MAR. I will have to look for "Rose" next time I have the door panel off.
        • Dale C.
          • November 1, 1999
          • 844
          IMG_6846.jpgPat, How cool is that? One Rose and the other Pat, 14 and 15 Feb 1968 stamps. Dale
          • Dale C.
            • November 1, 1999
            • 844
            Pat, If we have to do the re-skin option with CA, they have a new vapor barrier out now that looks like it might work, as it is vacuum formed and has the contours. Dale
            • Dale C.
              • November 1, 1999
              • 844
              IMG_6850.jpgBetter picture of Rose
              • Jeff P.
                • 799
                Who is doing the vapor barriers? Thanks, Jeff. I kept one of my originals . I didn't know anyone makes one.
                68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
                2014 Arctic White Z51 Vert. (Wifes)
                • Dale C.
                  • November 1, 1999
                  • 844
                  It's a Corvette America item Door Panel Vapor Barrier #39945 and they sell the door panel skins for $99.99, #440720 in black. They have a site http://www.corvetteamerica.com.
                  • Jeff P.
                    • 799
                    Thanks, Dale
                    • Patrick N.
                      • March 10, 2008
                      • 954
                      Originally posted by Dale Carlson (33147)
                      [ATTACH=CONFIG]48055[/ATTACH]Better picture of Rose
                      Very cool! I will check for Pat on my other one once I get home. Thanks for the info on the re-skin, the vac form seems like a good way to go if I cant fix mine.
                      • Dale C.
                        • November 1, 1999
                        • 844
                        Talked to Corvette Am and the skins are not what I thought. They cover the old panel. Like reroofing over the old roof. Not good. Back to square one. Off to see if can be repaired.
                        • Lyndon S.
                          • April 30, 1988
                          • 1027
                          They take the old skin off and use your substrate with the names and dates on them, unless your substrate is real bad you will not be able to tell they have been re skined I had mine done in the early 80s by CA. Because I wanted to save my dated door panels. And. They came out excellent and 30 plus years later still look great.
                          • Patrick N.
                            • March 10, 2008
                            • 954
                            Thanks Lyndon, did you have the car judged?
                            Here is the date on my other door, Dale, is this "Pat"?
                            • Lyndon S.
                              • April 30, 1988
                              • 1027
                              Yes, and they did well in flight judging .
