So, I have an original delco-remy headlight switch and a later reproduction headlight switch. Both switches work as they should when put in my 67. Neither switch works properly in my 65. In the 65 the park lamps do not turn off when the headlight are on. This occurs with either switch. Both switches work properly in the 67.
The 65 is a mostly original old car and as such has a few battle scars...the harness connector for the headlight switch has some melted plastic...evidence of a prior mishap. I cannot tell that any wiring has been replaced or altered in the circuit however. The park lamps turn on, the signals work properly, the headlights work properly but the park lamps do not turn off when the headlights are on.
Anyone have a suggestion to troubleshoot this....is there somewhere in the headlamp harness I should look? or ???
Thanks in advance for any suggestions.
Gary
Gary
