I bought the tool. Lefty loosey righty tighty right? Turn counter clockwise no problem till I come close to the end. I didn't try to force it. The small hole on the facia. Do I have to stick in say a paper clip to release it? Many thanks as always.
68 ignition cylinder removal
Re: 68 ignition cylinder removal
Jeff. I use a paper clip and stick it in the hole and turn the switch it to the right I believe. It should come right out.Jack Corso
1972 Elkhart Green LT-1 Coupe 43,200 miles
Top Flight 1994, 2018 & 2021- Top
Thank you jack and Jeff. The outside ring that screws on to hold the switch in place has four notches in it. I bought the tool to take the ring off. I get to a point where I can't loosen it any more. I don't want to force it. Any thoughts?68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
2014 Arctic White Z51 Vert. (Wifes)- Top
Thank you. The cylinder had to come out first before you can take the ring off. Yes Jeff the key has to be in acc. To pull out. Thanks, guys another baby step to resto heaven.68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
Jeff just to shift gears to another topic; do you know how long the return line rubber hose is, at the bottom by the fuel pump? This would be the section of rubber fuel hose where the two metal return lines come together.- Top
Jeff ,is this the hose your talking about?Attached Files68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
Jeff,I measured 10 1/8 inches.Attached Files68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
