1969 Fan Shroud Issue - NCRS Discussion Boards
  • Michael C.
    • January 9, 2013
    • 332
    390HP with A/C. Working to install new DeWitts aluminum radiator to replace my leaky copper rad. I completely removed the rad., shroud, support and A/C condenser. I tried to upload a photo showing my issue, but no luck. There is a gap of about 9/16" between bottom of the new rad and the new bottom shroud seal (from Doc Rebuild). This gap is at the bottom/center. Approximately 1/4" at each end. Same gaps with the old radiator. The fan shroud number matches the AIM. It's like the bottom of the shroud is bowed downward.
    Is such a gap typical? Can anything be done to tighten things up?
    Mike
  • Paul K.
    • February 1, 2002
    • 160
    Re: 1969 Fan Shroud Issue
    My 390HP with Ac shroud had the same bow your talking about, I think over time with heat, they bow. I ended up getting a new shroud to get the seal from Doc rebuild to work
    • Michael C.
      • January 9, 2013
      • 332
      If heat contributed to the bow effect, I wonder if I can heat that area (gently) to restore it to its original shape. Of course I don't have 40+ years to wait.
      Paul, where did you get your new shroud? Happy with it?
      • Dick W.
        • 10483
        Mike
        Very common with these shrouds. Personally I think it is nothing to worry about.
        Dick Whittington
