1970 Engine Pad vs Cast Date - 10 months? Please help - NCRS Discussion Boards
  • Steven S.
    • June 27, 2013
    • 86
    Hello again. I have a thing for 1970 Corvettes, and found another one I would like to buy. The problem with this one is, there is a 10 month lag between the Casting Date and the Stamp Date on the engine block.
    Please let me know your opinions about this, after looking at the photos below of the Trim Tag, Cast Date, and Pad Stamp. It is a simple 300hp car, 4-speed. I do not think the motor has ever been out of the car, so I am here to ask for your opinions.
    The owner has had the car for 15 years, and does not know much about Corvettes. The previous owner had it more than 10 years, and also lived in the small tow where the current owner is.
    He had to use a lot of brake cleaner and elbow grease to get the Casting Date readable, and that is when I discovered it is June 2, 1969. As I was photographing the Cast Date, I didn't know, but he was using a Scotch-Brite pad to clean the Engne Pad so we could read it better. We could not see the top, right side of the 1 in April 1st before the cleaning, and now you can see that the 1 looks like a capital letter i.
    The Build Date of the car is May 13, 1970. The engine Pad Stamp is April 1, 1970. This is a 10 month lag between Cast Date and Stamp Date. From what I have read, the NCRS guidelines are only 6 months. I know that 1970 was a crazy year, after the UAW strike in 1969, so it is possible that this could be a legitimate 10 month lag between Cast and Strike dates?
    Please have a look at the photos below, and let me know your opinions.
    Car VIN # 9140
    Car Build Date - May 13, 1970
    Block Cast # - 3970010
    Block Cast Date - June 2, 1969
    Block Stamp- 70s409140 V0401CTD
    Thank you again,
    Steve Sperrazza
  • Pat M.
    • April 1, 2006
    • 1582
    Re: 1970 Engine Pad vs Cast Date - 10 months? Please help
    Bump. Steven, I'm no pad expert, and can't comment on the cast/stamp date differential, but the characters on the stamp pad I can see look really similar to my 70 base car's pad (placement, depth of certain characters, unique lookng "1" on engine code), which has never been questioned in judging. Hopefully, someone more experienced will comment on your ultimate question.
    • Steven S.
      • June 27, 2013
      • 86
      Hi Pat,
      Thank you for your input here. I looked at the car again, and bought it. I am a sucker for a white 70 convertible, lol. Can't wait for it to be delivered to Boca Raton soon.
      Have a great weekend,
      Steve
      • Kenneth H.
        • October 27, 2008
        • 500
        Steve, congratulations, and when you get your new purchase home, take a closer look at the casting date. You might be pleasantly surprised. Try cleaning it again. The "9" in the casting date could actually be a "0" that either has some nasty crud on it or could have been moderately damaged over the years.
        • Michael W.
          • April 1, 1997
          • 4290
          Let's hope not. A June '70 cast block would be well after the assembly date for both the engine and car.
          Congrats on buying the car Steve. Think it will go well with your white tutu?
          • Peter S.
            • March 28, 2012
            • 327
            Unless I am missing something, I think you have mistaken Steve for someone else.
            Peter
            • Kenneth H.
              • October 27, 2008
              • 500
              Oops! That wouldn't work, would it? Instead of being "pleasantly surprised" Steve would be a very unhappy camper.
              • Michael W.
                • April 1, 1997
                • 4290
                ooops! You're right. Gotta get my avatars right!
                Peter
                  • 15630
                  Originally posted by Steven Sperrazza (12077)
                  Hi Pat,
                  Steve
                  Steve,
                  I too am a sucker for 1970s. Bring that thing to the Winter Regional in January. I want to see it.
                  How far is Boca from Orlando?
                  • Steven S.
                    • June 27, 2013
                    • 86
                    Hi Terry,
                    I will definitely be in Orlando/Kissimmee this January. The drive is about 3 hours on the Florida Turnpike from Boca Raton.
                    I look forward to meeting you there.
                    Steve
                    Steve,
                      • 15630
                      Hi Terry,
                      Steve
                      I plan to be there, so let's stay in touch.
                      • Paul D.
                        • January 1, 1988
                        • 101
                        I had a 1970 coupe vin 15xxx mid july car loaded....350/350hp.......block was cast in Dec '69.....I was 3rd owner...
                        • Mark E.
                          • April 1, 1993
                          • 4607
                          On my 1970, it's nine months from engine block casting (H259) to engine assembly (T0608CZU):
                          VIN: 194370s412931
                          Certification label on door jam: 194370s412931 R 6-70 (June 1970)
                          Body build date from trim plate: F22 (June 22)
                          Engine pad: 70S412931 T0608CZU (Suggests engine assembly on June 8, 1970)
                          Cyl head casting # & dates: 3964290 D1570 (both) (April 15, 1970)
                          Intake manifold casting # & date: 3855287 E870 (May 8, 1970)
                          Engine block casting # & date: 3963512 H259 (August 25, 1969)
                          See my separate thread from March 2015: "Can this 1970 LS-5 block casting date be original to the car?"
                          Mark Edmondson
                          Dallas, Texas
                          Texas Chapter
