1976 oil pressure sender configuration - NCRS Discussion Boards
    • 11669
    Does anyone happen to know the correct configuration of the oil pressure sender for a 1976 Corvette? I'm working on the car of a friend, and he needs a new sender. When I search for one there appear to be about 3-4 different configurations available depending on who makes it. I want to be sure to get one that at least looks as correct as possible.
    Any thoughts?
    Patrick
    • 43248
    Re: 1976 oil pressure sender configuration
    Any thoughts?
    Patrick
    Patrick------
    My recollection is that it's a "canister" style unit and it's painted black.
    1976 may have used one of two senders. Early used GM #6462137 (same as 74-75). Late used GM #370801. I don't know how they differed in configuration. Believe it or not, I don't have either one.
    This sender had a lot of "iterations" over the years as follows:
    GM #6462137>GM #370801>GM#547034>GM #14039612>GM #14040816>GM #15591103>GM #19244935 (current)
      • 11669
      Thanks Joe. It's about $44 on Amazon, and I'll let the owner know.
      Patrick
