72 wiper space - NCRS Discussion Boards
72 wiper space
  • Rey S.
    • April 1, 1995
    • 277
    72 wiper space
    How much space (clearance) is there below and forward of the wiper mechanism? I wish these dimensions as I plan to drill thru the bulk head and route some of my vacuum lines thru the wiper bay. My wiper mechanism is not yet installed and correctness is not an issue !
    Rey Stenhouse 26007
    1972 LS-502 coupe
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 72 wiper space
    Rey, curious, why do you not want to use the original hole the original vacuum hoses are routed through?
    • Rey S.
      • April 1, 1995
      • 277
      Re: 72 wiper space
      Hi Jim: As I stated correctness is not an issue. I wish to route the vacuum lines thru the wiper trough so as to clean up the fire wall. If there is enough room in the areas I mentioned I may route some of the wiring through there also! With no wiper mechanism installed I am unable to take clearance measurements. Thanks for your reply. Rey 1972 LS-502 coupe
