Help getting my 1981 ventilation panel to illuminate - NCRS Discussion Boards
  • Ciro A.
    • October 17, 2006
    • 71
    I'm on the road this week so I don't have access to my car but figured I'd take advantage of the expertise of NCRS members. Where are the lightbulb/s located that illuminate the ventilation panel on a 1981 Corvette. I'm hoping its an easy bulb replacement. All help is appreciated
  • Arland D.
    Moderator
    • July 31, 1980
    • 430
    Re: Help getting my 1981 ventilation panel to illuminate
    Directly above the controls on the underside of the dash pad is a panel with two philips head screws. The light is mounted on the top side of the plastic panel and is an unusual bulb in an unusual socket.
    • Steven B.
      • June 30, 1982
      • 4021
      Arland, is it a "wheat" bulb"? Thanks, Steve
      • Arland D.
        Moderator
        • July 31, 1980
        • 430
        Steve,
        I must have led a sheltered life - never heard of a "wheat" bulb. As I recall, the bulb is pinched flat at the bottom with the two wires exiting through the bottom and running up the sides.
        • Steven B.
          • June 30, 1982
          • 4021
          Yep, that is what we used to call a wheat bulb. I don't know the real name.
            • 15646
            I have a couple of those bulbs (based on Arland's description) on my Caprices. I get replacements from Radio Shack. $1.98 for 2 of them. I can get you some Radio Shack numbers if you have a number for the Corvette panel bulb. There is a twist in holder that retains the bulb and the wire leads twist around notches in the holder. It takes good eyes and a steady hand to replace them. Does that sound like them?
            • Ciro A.
              • October 17, 2006
              • 71
              Thanks guys, i knew you would help!
              • Arland D.
                Moderator
                • July 31, 1980
                • 430
                Terry,
                That sounds exactly like the set up in the Vette - mine was mangled at the factory but that is a long story.............................
                • Ciro A.
                  • October 17, 2006
                  • 71
                  Arland,
                  I will look for this panel, but I'm curious to know what do you mean by Dash Pad. The only dash pad I know is on the top of the dashboard, the ventilation controls are in the center console. Appreciate your help.
                  • Arland D.
                    Moderator
                    • July 31, 1980
                    • 430
                    Ciro,
                    Look directly up from the controls at the underside of the dash and you will see the plate - hence the underside of the dash pad.
                      • 15646
                      Let's see how this works: Radio Shack catalog number 272-1092. #7219 Micro Lamp (package of two) shows $1.99 in the on-line catalog. Ordering from the on-line catalog will kill you with shipping. One of the advantages of living in a large metro area is I can walk a couple of blocks to a Radio Shack store that has these in stock. If they are out I can drive about a mile to another.
                      We used to call these "grain of wheat" bulbs when they first came out, and that was more than a few years before your 1981 was built
                      • Ciro A.
                        • October 17, 2006
                        • 71
                        Thank You Arland and Terry!
                        • Arland D.
                          Moderator
                          • July 31, 1980
                          • 430
                          Terry,
                          The bulb that was removed and the new bulb did not have the long wires running wild out of the bulb. The wires were short, pre-formed little loops running back up the sides of the flattened glass at the bottom.
                            • 15646
                            Originally posted by Arland Dower (3734)
                            Terry,
                            Then the one I posted is something different. Sorry, I tried.
                            • Ciro A.
                              • October 17, 2006
                              • 71
                              Arland and Terry,
                              So as I understand this system the ventillation control panel is not backlit internally but illuminated from above via the bulbs in the dash underside? Just curious as I am not home and cant loook at my car. I seem to remember the controls being backlit internally
