1967 Rear Trailing Arm Spiral Brake Lines - NCRS Discussion Boards
  • Timothy B.
    • April 30, 1983
    • 5203
    I have read in the archives about spiral brake lines at the rear calipers but what's the consensus with 1967 cars.
    Did GM use spiral brake lines at the rear calipers or not..
  • Larry M.
    • January 1, 1992
    • 2703
    Re: 1967 Rear Trailing Arm Spiral Brake Lines
    Yes.
    Larry
    • Gene M.
      • April 1, 1985
      • 4233
      By "spiral brake lines" are you refering to the armor wound around the lines on the trail arms. If so the previous answer is good.
      • Timothy B.
        • April 30, 1983
        • 5203
        Thanks Larry and Gene, I am replacing the rear lines on my 67 and the armored lines are the only ones available from Paragon so I will use them.
        Anyone know what year GM changed to the NON armored lines?
          • 15640
          For C3s only on BB were brake lines on the trailing arms armor wrapped. Probably due to the proximity of the rear stabilizer bar. So the answer to your question would be 1968 SB.
