Ball Joints - NCRS Discussion Boards
Ball Joints
  • Peter S.
    • March 28, 2012
    • 327
    Ball Joints
    All,
    Any recommendations on correct ball joints? Paragon part #13093K and 13094K? Does anyone have any experience with this ball joint, both performance and judging?
    Peter
  • Steven B.
    • June 30, 1982
    • 4021
    Re: Ball Joints
    Peter, I have not tried the Paragon ball joints. When I replaced a couple of ball joints on my '77 during a suspension change about '79 my dealer told me the stock joints were the same as the ones used on 4X4 Blazer and pickups. I never checked it out. Maybe someone knows for certain. I do not have my parts books with me. If accurate you can possibly find originals.
    Steve
    • Peter S.
      • March 28, 2012
      • 327
      Re: Ball Joints
      Thanks for the response Steve. I'll check with my local dealer if they know, and if they have the part #. Peter
      • Peter S.
        • March 28, 2012
        • 327
        Re: Ball Joints
        I'm also open to any other suggested ball joints that will judge correctly.
        Peter
          • 43295
          Re: Ball Joints
          Steve
          Steve------
          The 1963-82 Corvette ball joints, both upper and lower, were not the same as those used on pick-up trucks and blazers.
          • Mike E.
            • June 24, 2012
            • 920
            Re: Ball Joints
            Peter ---
            Here are a couple of threads that make some comparisons between original and reproduction ball joints for C2s & C3s.
            https://www.forums.ncrs.org/showthre...on+ball+joints
            For the most part they are close but not exact. In any case they should riveted in place receive maximum points. Are you sure yours need to be replaced? Lowers fail most of the time before uppers.
            Mike
            • Steven B.
              • June 30, 1982
              • 4021
              Re: Ball Joints
              Steve------
              Thanks Joe! I knew you would know. What other GM vehicles shared the same ball joints?
              Steve
                • 43295
                Re: Ball Joints
                Steve
                Steve------
                The only other models I know of are 1958-70 full size passenger cars. That's to be expected, though, because 1963-82 Corvette front suspension is very similar to 1958-64 full size passenger car and many parts interchange.
                • Peter S.
                  • March 28, 2012
                  • 327
                  Re: Ball Joints
                  Originally posted by Mike Eby (55078)
                  Peter ---
                  Mike
                  Hi Mike,
                  Yes, they are in desperate need of replacement. Thanks for your links, seems to be much discussion on the subject. I may have taken the site for granted in hoping for a direct recommendation. I still hold out hope that someone has used a replacement ball joint, have judged fairly well (minor deduct) and perform great!
                  Peter
                  • Kurt G.
                    • April 30, 2005
                    • 343
                    Re: Ball Joints
                    Corvette America and Corvette Central both have correct configuration ball joints.
                    Kurt Geis
                    Chairman, Midway USA Chapter
                    Targa Blue 1972, Top Flight and Duntov Award, 2014
                    Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
                    Arctic White 2013 60th Anniv Special Edition Conv.
                    • Peter S.
                      • March 28, 2012
                      • 327
                      Re: Ball Joints
                      Kurt,
                      Any experience on the judging field with their ball joints?
                      Peter
                      • Kurt G.
                        • April 30, 2005
                        • 343
                        Re: Ball Joints
                        Yes. They judged great. Just make sure they are riveted in place. One other good thing. Ball joints are considered a safety item and as such are no longer judged as they used to be, but installation still is critical. No bolts or screws.
                        Kurt Geis
                        • Richard M.
                          • April 1, 1993
                          • 198
                          Re: Ball Joints
                          Peter, the part no. for the GM lower ball joint is 88911514, AC/Delco # 45D2016 they are made in the USA by Spicer, I've been told that the Moog brand is better, I do not know how either of these come out in judging but if riveted in place they should do fine. RichardMynatt
                            • 43295
                            Re: Ball Joints
                            Richard-----
                            These ball joints are not configured like the originals. However, they are 100% equally functional.
                              • 11698
                              Re: Ball Joints
                              Ball joints are considered a safety item and as such are no longer judged as they used to be...
                              Kurt,
                              as a frequent chassis judge I have yet to hear that statement or see it in print. I have only seen this comment with regard to flexible brake hoses.
                              Patrick
