61/62 Steering Wheel Screw - NCRS Discussion Boards
  • Terry D.
    • May 31, 1987
    • 2696
    Anybody have an extra screw that holds the steering wheel on? After completing a turn signal project I seem to have lost one darn screw. Thanks in advance Terry
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: 61/62 Steering Wheel Screw
    Terry,
    Doesn't 1 large nut hold the steering wheel on?
    • Dick W.
      • 10483
      Terry,
      Wheel is held on the hub by screws
      Dick Whittington
      • Mike E.
        • February 28, 1975
        • 5141
        Isn't the wheel (spokes) fastened to the hub with flat head rivets?
        • David L.
          • July 31, 1980
          • 3310
          I believe that the 6 screws that hold the 1961-1962 steering wheel in place are probably the same ones that were used on early 1963 models, GM # 769611, which as best as I can remember are 10-24 X 1/2" Phillips flat head machine screw. The 769611 screw was replaced by the 9418712 screw in January 1963 (revision record in AIM).
          Dave
            Mike -
            As I recall, yes, and CC has made a flat-head machine screw for many years whose plain head looks just like a rivet to re-assemble a hub and wheel that have previously been separated.
            • Mike E.
              • February 28, 1975
              • 5141
              John,
              you are correct. The originals are 6 flat-head countersunk rivets stainless steel, peened on the back side of the hub flange into a domed shape. CC has sold replacements that were similar in appearance on the steering wheel surface, threaded, with nuts that retain it to the hub flange, which is extremely difficult to detect once installed.
              • Terry D.
                • May 31, 1987
                • 2696
                Thanks guys
