1110914 Distributor I.D. Help? - NCRS Discussion Boards
  • Mark S.
    • February 1, 2002
    • 110
    See attached photo. Any help to I.D. Thanks Mark
  • David L.
    • July 31, 1980
    • 3310
    Re: 1110914 Distributor I.D. Help?
    Mark,
    The 1110914 distributor was used on mid-1958 thru 1960 Corvettes w/290 HP & 1961 Corvettes w/315 HP F.I. engines according to the NCRS 1953-1972 Corvette Specification Guide (Vol. 16, No. 1 - Summer 1989).
    It was still available over the counter in May 1965 as per my 1965 Chevrolet Parts Catalog and removed from service in July 1972 as per Chevrolet Parts History.
    Dave
    • Loren L.
      • April 30, 1976
      • 4104
      It's a service replacement built August '64 - a hellacious crime indeed! Change the tag and go on your way.
      • John D.
        • December 1, 1979
        • 5507
        Mark, '914 would be correct for Jan or so 1958 HHP until 1961HHP. The earlier '58's HHP used a 908.
        The service replacement one in the photo (that Loren pointed out) may have a different cam in it. John
        There is one 100% accurate repro tag on the market today. Easy to spot other repro tags as they don't have the correct characters. Notice the two different 1's used. That's typical.
        • Mark S.
          • February 1, 2002
          • 110
          Any thoughts to the current value of this distributor?
          • Don H.
            • December 1, 1981
            • 1501
            Mark, The last I followed them (a few years ago) they were around $1000. That could be affected by the fact your date code does not match any applications. It would work fine with a F. I. unit but probably would have to replace the tag for judging. Good Luck, Don H.
