Intake manifold - NCRS Discussion Boards
Intake manifold
+ More Options
Posts
  • Bradley D.
    • May 27, 2012
    • 87
    Intake manifold
    Okay, I've gotten the intake off, and sent to be reconditioned. Any tricks I should know about on the re-install. I getting a new bypass hose and nipple, a new temp sending unit, will use thin stainless washers and of course a complete gasket set all round. Any other tricks I need to do to have a smooth install?
    Brad Davenport
  • Carl N.
    • April 30, 1984
    • 592
    Re: Intake manifold
    just be sure to follow correct torque sequence and torque amount and re-torque after a few drives and check coolant level
      Re: Intake manifold
      Bradley -
      You may find this article useful for your installation:
      http://www.lbfun.com/warehouse/tech_...ntake_Swap.pdf
      Why are you replacing the temp sending unit? If it's original, it's likely more accurate than any aftermarket replacement.
      • Bradley D.
        • May 27, 2012
        • 87
        Re: Intake manifold
        Bradley -
        Its likely it won't come out in one piece, so I'm prepared to replace. I really don't think it original, but it does work fine. Thanks for the link.
        Brad Davenport
