Early Muncie Shift Levers - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    Are early Muncie shift levers the same regardless of the vehicle that the transmission was used in? To be more specific, I'm trying to find an original 3-4 shift lever, P/N 3859943 for my brother's 67 Camaro and I'm wondering if Corvettes in those years used the same P/N shift levers? I'm heading to Carlisle next weekend and it would make his day if could bring one back for him.
  • Steven B.
    • June 30, 1982
    • 4000
    Re: Early Muncie Shift Levers
    Greg, unlike the Corvette lever the shift lever in the Camaro was a curved, flat stock piece that is very close in shape to a Hurst Competition Plus. As you know the Corvette is a shorter lever with reverse lock out. Rick's Camaro and Classic Industries are a few that the Camaro unit.
    Good Luck!
    Steve
    • Greg L.
      • March 1, 2006
      • 2291
      Hi Steve, I'm actually talking about the shift levers that are on the transmission. His 1-2 and reverse levers are correct but the 3-4 lever is wrong. I think I found my answer late last night and the Corvette ones appear to be different.
        • 43247
        Greg-----
        GM #3859943 was used on many Camaros, Chevy II's, Chevelles, and some full size passenger cars. It was also used on some Buick, Pontiac, and Oldsmobile models (probably A bodies). However, it was never used on a Corvette.
        • Greg L.
          • March 1, 2006
          • 2291
          Thanks Joe, that confirms it then. I was hoping that I might get lucky at Carlisle but probably not. Would you happen to know of a source for this lever other than ebay because near as I can tell they aren't reproduced.
          • Steven B.
            • June 30, 1982
            • 4000
            Greg, try Rick's and Classic for the rods. Good Luck, Steve
            • David L.
              • July 31, 1980
              • 3310
              Greg,
              There is a set of NOS levers currently on Ebay (not mine).
              Dave
              • Ray G.
                • May 31, 1986
                • 1189
                Dave;
                Are those Corvette levers ?
                I hope you dance
                • David L.
                  • July 31, 1980
                  • 3310
                  Originally posted by Ray Geiger (9992)
                  Dave;
                  No, they are GM # 3859942, 3859943, and 3857412. The seller has listed the applications but I have not verified what he has listed with all of my vintage Chevrolet parts catalogs.
                  Dave
                  • Ray G.
                    • May 31, 1986
                    • 1189
                    Thinking here the Corvette 1-2 & 3-4 levers are much longer.
                    Can't find the numbers at this writing.
                    I hope you dance
                    • David L.
                      • July 31, 1980
                      • 3310
                      The 65-67 shifter levers are 3864402 (1-2), 3864403 (3-4), and 3846891 (R).
                      The 64 shifter levers are 3846889 (1-2), 3846890 (3-4), 3846891 (R).
                      3846890 to 3850113 in Mar. 1964 as per Chev. parts history (over the counter parts).
                      • Ray G.
                        • May 31, 1986
                        • 1189
                        Thank you Dave
                        I hope you dance
                        • David L.
                          • July 31, 1980
                          • 3310
                          Ray,
                          There are shop drawings of the 3864402 and 3864403 levers in Noland Adams 63-67 Corvette restoration book on page 292. Each lever measures 3.79" from the center of the top hole to the center of the slot. Somewhere in my garage I have a 3846891 reverse lever.
                          Dave
                          • David L.
                            • July 31, 1980
                            • 3310
                            Ray,
                            Pictured below are the original shifter levers from my 1966 Corvette. The overall length of the "1-2" (3864402) and "3-4" 3864403) lever measures about 4 11/16" and the overall length of the "R" (3836891) lever measures about 2 5/16". There is a stamped "X" on the backside of the "1-2" and "3-4" levers.
                            The 1964 levers, GM # 3846899 and 3846890, do not have the hole at the midpoint. This hole was added on 1965-1967 levers for a "faster shift" adjustment.
                            Dave
