Does anyone know who carries the steel oil pressure line for a 1968 427? This is the full 44" steel line. Dr. Rebuild used to but no longer. One end got over tightened. Can it be re-crimped? Thanks for your ideas.
1968 steel oil pressure line supplier??
Bill Hyndman
The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
1962 Big Brake Fuelie
1965 Fuelie Convertible
1968 L89 Convertible
Tags: None- Top
Re: 1968 steel oil pressure line supplier??
Paragon has them, but if you have a mini-tubing cutter, cut off about 1/2" of the over-crimped end and button it up again.- Top
