'57 trunk driver side tool hold down clamp change/revision? - NCRS Discussion Boards
  • Steven B.
    • June 30, 1982
    • 4016
    Did the trunk driver side tool hold down clamp change or was it revised between '56 and late '62?
    Steve
  • Gary C.
    Administrator
    • October 1, 1982
    • 17969
    Re: '57 trunk driver side tool hold down clamp change/revision?
    Steve,
    Check the '57 JM.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Steven B.
      • June 30, 1982
      • 4016
      It is packed for the move. I will let you know where we end up! Sept 13 looks like the day. I have transport for them and found a place to store the Corvettes if needed. Thanks for telling me about Carlos.
      • Gary C.
        Administrator
        • October 1, 1982
        • 17969
        Several styles of lug wrench and jack handle hold-down metal spring clips were used. The 1st design 1956 tool clip (used for both wrench and jack handle) was riveted to the trunk deck; the 2nd design 1956 tool clip used bent position retaining tabs through two small holes in the trunk deck, each secured with a single #8 Phillips screw, and was used through approximately 1957 serial number 4750; a 3rd design clip secured the lug wrench and attached with two #8 Phillips screws, while the jack handle clip was J-shaped, attached with a single Phillips screw. Tool attaching clips and screws were in place when trunk was painted.
        Good luck with the move!
        NCRS Texas Chapter
        • Steven B.
          • June 30, 1982
          • 4016
          Thanks Gary!
