1954 Parking Brake flasher - NCRS Discussion Boards
  • David W.
    • May 31, 1990
    • 51
    Where can I find a schematic diagram for wiring up the flasher for the parking (emergency) brake warning light? Could use info on the proper mounting of the flasher. Thanks
  • Chris S.
    • January 1, 2000
    • 1067
    Re: 1954 Parking Brake flasher
    The 57 is similar.....
    The mounting is the same on the parking arm.....
    One wire goes to the flasher....
    One wire goes to the switched power side....
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • David W.
      • May 31, 1990
      • 51
      Thanks, Chris. That will help. Dave
      • Troy P.
        • February 1, 1989
        • 1284
        • Troy P.
          • February 1, 1989
          • 1284
          BTW the wires should be black as shown in the photo. Not tan like the repro wiring harnesses. They weren't tan until 55 12V.
          • David W.
            • May 31, 1990
            • 51
            Hi, Troy...many thanks for the info and the clear picture. I was looking at the repro wires which are tan as you said.
            • Troy P.
              • February 1, 1989
              • 1284
              You can make your own black wires if yours are bad.
              The flasher light socket must have been made for some other GM vehicle because the wires are way longer than they need to be for a Corvette.
              • David W.
                • May 31, 1990
                • 51
                Thanks, Troy...The wires are black.
