alternator rebuild - NCRS Discussion Boards
alternator rebuild
  • Bill W.
    • March 1, 1980
    • 2000
    alternator rebuild
    I have a nice 31,000 mile 65 alt. The only problem is the diodes have aged and the numbers and dates cant be read anymore . Does anyone sell correct dated diodes or stamps and how do you press them in without damage . I have sent parts to John Pirkle Sr. in the past and he did a great job but I would like to do this myself if possible .
  • Alan D.
    • January 1, 2005
    • 2054
    Re: alternator rebuild
    John Pirkle has them, call.
    • Bill W.
      • March 1, 1980
      • 2000
      Thanks , I called John and they are on the way .what have others used to press the diodes in ?
      • Dick W.
        • 10483
        Let me look, I used to have the pieces to press them in, been 35 years since I have done that
        Dick Whittington
        • Joe R.
          • July 31, 1976
          • 4552
          Bill,
          You can use a small deep well socket and the lead will fit inside the socket as you will press from the back side. You also need a hydraulic or mechanical press. You can substitute a large c clamp if necessary. Go slow and easy and you will be proud of a perfect job.
          JR
          JR
          • Dick W.
            • 10483
            Bill, I cannot find my diode press set. As Joe Ray stated, a socket will work, just take your time.
            Dick Whittington
            • Bill W.
              • March 1, 1980
              • 2000
              Thanks Joe & Dick
