I pulled my transmission because I was getting noise when the clutch was depressed. Eveything checked out including the throw out bearing which I had replaced last year when the tranny was rebuilt. The problem appears to be the input shaft bushing which I had forced in 3 years ago. the reason I say forced is because I found out later I had squeezed a standard size pilot shaft bushing into a powerglide crank which should not fit. I think it caused an early failure of the bushing. My problem is I just ordered and received a Dorman powerglide adapter pilot bushing that should be a proper fit to replace the failed bushing but it is magnetic. I've heard nothing good about using magnetic pilot shaft bushings on the post I read here. I hate to put that magnetic bushing into that crank if its going to fail prematurely, and I lay under my car on jack stands to do all of this work which is no fun for a 66 year old guy. I guess my question is why would they make these bushing with this material if they will fail early? Or are they OK to use? Any feedback would be greatly appreciated.
Thank You in advance.
Jeff
Jeff
