'64 Heat Riser question - NCRS Discussion Boards
  • Norris W.
    • December 1, 1982
    • 685
    This is one of those embarrassing questions that I THINK I should know the answer too, but can't come up with it:
    Did the mid year fuelie cars have heat risers? I'm trying to figure what purpose they would serve on a fuel car, but don't recall knowing that they don't. If they don't use the heat riser, does it need a spacer on the left side for the pipe to fit right?
  • Bob J.
    • December 1, 1977
    • 720
    Re: '64 Heat Riser question
    Norris, the 64 FI engines used a spacer, not a heat riser with a valve.
    • Norris W.
      • December 1, 1982
      • 685
      Thanks Bob. Is that true with the '62's and '63's also?
      • Bob J.
        • December 1, 1977
        • 720
        Yes, I think 62 -65 used the same spacer.Bob
          • 15706
          No FI engines had heat riser valves. The FI spacer was just a partially machined heat riser valve body that didn't have the spring or valve. There is a 2" version used with 2" outlet manifolds, and a 2.5" version for 2.5" outlet manifolds.
          '64 FI engines have 2.5" manifolds and spacer.
          • Norris W.
            • December 1, 1982
            • 685
            Thanks guys. I've actually used the spacer in the past on some stock appearing Big Block stuff that had manifolds that I didn't want a heat riser in, so I'm familiar with the 2 1/2" version.
            What I'm REAL unfamiliar with is fuelie stuff. I've got 2 of 'em of my own that I've never heard run (I've never even ridden in a fuelie) and a friend just bought a '64 Coupe that's not all he thought it'd be, so I guess I'm looking at a steep learning curve helping him with it while re kindling the enthusiasm for two of my old warehouse queens.
            • Stuart F.
              • August 31, 1996
              • 4676
              The spacer is on the right side, and the reason fuelies don't have a heat riser valve is because they do not have exhaust cross over passages in the manifold like a carbureted engine to preheat the mixture. The passages are in the heads, but are blocked off at the manifold.
              Stu Fox
