Primer Removal - NCRS Discussion Boards
Primer Removal
  • Jim D.
    • August 31, 1997
    • 58
    Primer Removal
    What's the best way to remove primer? I've tried using Acetone and a scrub brush but its not working or I'm not doing something right.
  • Jim T.
    • March 1, 1993
    • 5351
    Re: Primer Removal
    What are you removing primer from?
    • Bill W.
      • March 1, 1980
      • 2000
      Re: Primer Removal
      Lacquer thinner and a red scotch bright pad .if it is lacquer primer .
      • Dick W.
        • 10483
        Re: Primer Removal
        At, for the days of yesteryear. Lacquer removing solvent and Scotchbrite pads. Strip a Corvette in just a few hours, down to the bare glass. Carcinogens, Nah, we never worried about such things
        Dick Whittington
        • Gene M.
          • April 1, 1985
          • 4232
          Re: Primer Removal
          Jim,
          If it is a catalyzed primer, lacquer thinner will not touch it. You will need a stripper to remove or a lot of sanding. But if it is a catalyzed primer why not leave it?
          • Bill W.
            • March 1, 1980
            • 2000
            Re: Primer Removal
            The old paints and primers were full of lead .Because that was bad for us painters / bodymen they replaced it with catalyzed primers and paint with "the good stuff " isocynates . Now along with the lead poisoning we get cancer and melanoma .
            • Timothy B.
              • April 30, 1983
              • 5184
              Re: Primer Removal
              Originally posted by Gene Manno (8571)
              Jim,
              My thoughts exactly, why not leave it..
              • Jim D.
                • August 31, 1997
                • 58
                Re: Primer Removal
                How can you tell what kind of primer it is? I know its not the original cause the car was repainted an non-original color in the late 80's. The car was originally white and it was painted red. I've stripped the red off but I come across a dark grey layer, I've tried some acetone on it but it didn't do anything. BTW, the car is a 66.
                • John M.
                  • January 1, 1998
                  • 813
                  Re: Primer Removal
                  Jim, I took off what I could with Captain Lee's stripper which left the red primer (it's a 67) which I then wet sanded off to keep the dust down. That red stuff is extremely rugged and probably doesn't need to come off. I removed it because the painter wanted it gone. Not a huge job but time consuming.
                    • 15663
                    Re: Primer Removal
                    What John said... Unless you suspect a problem with the undelying fiberglass and you want to expose it for inspection, there is really no need to remove the reddish-brown OE primer. A backside inspection will usually reveal any previous fiberglass repairs that you may want to expose to see if it any rework is needed.
                    About the only way I know of to remove the that OE primer is sanding. I don't know of any paint stripper or solvent that will attack it. It's like armor plating on a battleship - very tough, durable, long-lived stuff.
                    I wonder if today's primers are as good.
                    • Dick W.
                      • 10483
                      Re: Primer Removal
                      The old lacquer removing solvents would work with a Scotchbrite pad. Today's primers are like comparing granite to peanut butter
                      Dick Whittington
                      • Jim D.
                        • August 31, 1997
                        • 58
                        Re: Primer Removal
                        Duke, Its not the OE primer, car was repainted an unoriginal color back in the late 80's, this stuff on it is dark grey and it won't come off with acetone.
                          • 15663
                          Re: Primer Removal
                          Then you'll have to use abrasive or some combination of abrasive and solvent that have been suggested.
                          Try sanding a small area first. I wouldn't be surprised if you see that OE primer just before you get to the fiberglass.
