I would like some help and expertize in figuring out the design of 63/64 Corvette FI PCV systems.
As many of you probably know, my 57 has a 1962 327 engine and I will be running a 1963 (375) rebuilt/restored FI unit. The engine currently has a road tube. This does not play well with the 1963 FI oil tube which introduces clean air into the crankcase from the FI air meter, for the 63 PCV system. What I would like to do is convert the system to a correct 63 or 64 PCV system. This has the additional benefit of then having a sealed crankcase which would be better here in upstate NY where high humidity and long winters predominate. The humidity here seems live on 98% and never goes below 50%.
What I have learned is the PCV design was changed sometime during the 64 model year, I think as a design improvement. I am having a hard time figuring out exactly how the PCV system is configured. I plan on buying all the components from one of our supply houses, probably Corvette Central as they seem to have the most complete offering. If someone has a photo or line drawing they could post it would be a big help. I think I am pretty clear on the adapter that replaces the road tube. There was a design change to this during 64, but I believe it was a process only change.
What I am not clear on is the PCV valve, how it connects to the adapter, and where/how it gets to the vacuum source in the FI plenum. Also I believe the 63 valve is different from the 64, and the FI valve is different from passenger car as well. I believe the later design FI PCV valve has an orifice to limit the amount of vacuum usage for FI metering. The 64 oil tube is different from 63 as well, I think the 64 has an orifice. I currently have a 63 oil tube that is not in very good shape.
So I have the following questions;
Can anybody supply a photo or line drawing.
Seeing how I am starting from scratch, would I be better off using the 64 design instead of the 63 design.
What specific valve should I buy.
How does it connect to the vacuum source.
Also I will be converting the 63 port vacuum spark advance to full vacuum. Can't seem to determine where and how the line gets to the plenum. I have a B22 VAC, the engine is hydraulic, low compression, so I would expect to have sufficient engine vacuum for the FI unit.
Any help would be much appreciated.
Thanks much
-Dan-
Thanks much
-Dan-
