396 oil pan - NCRS Discussion Boards
396 oil pan
  • Bill W.
    • March 1, 1980
    • 2000
    396 oil pan
    I have my original 396 oil pan from #16120 . It has lots of rust holes and is no longer usable . The judging manual says it should have two ribs pressed in the side of the sump . Mine is smooth and flat on the sides . I does have the correct drain bolt and drain location . I have not seen any of these for sale or reproduced . Does anyone else with an original engine have a smooth one and if so what serial number range ?
    • 43220
    Re: 396 oil pan
    Bill------
    Known-original 1965 L-78 oil pans that I have observed have two relatively short, impressed vertical ribs on the left side of the pan (I don't recall if they had any on the right side). Did every 1965 L-78 pan have the ribs? I don't know as I've not seen every one.
    • Gary C.
      • April 1, 1998
      • 376
      Re: 396 oil pan
      Hi Bill,
      There is more info here on L78 pans.
      https://www.forums.ncrs.org/showthre...=L-78+oil+pans
      Cheers,
      Gaz
      • Bill W.
        • March 1, 1980
        • 2000
        Re: 396 oil pan
        Thanks Gary , I didnt think about the front bolt hole . Mine does have it .
