67: What attaches to this???? - NCRS Discussion Boards
+ More Options
Posts
  • Dave K.
    • January 24, 2013
    • 278
    Can't figure out what was attached to this metal clip that was bolted to the differential support bracket that comes off of the crossmember. See pics. Dave
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 67: What attaches to this????
    It's the clip that holds the brake line going from left to right rear.
    • Dave K.
      • January 24, 2013
      • 278
      Thx Wayne...I figured it was a line for holding something. I,ve been good at taking pictures of everything before I disassemble, but I missed this one.
      • Stephen L.
        • May 31, 1984
        • 3162
        WOW!! That frame has some serious corrosion.
        • Dave K.
          • January 24, 2013
          • 278
          That is what you call PATINA.....Nothing a little sand blasting can't fix.
          • Michael J.
            • January 27, 2009
            • 7174
            Love to see a car with light patina, shows integrity and honesty...Good Luck!
            • Jeffrey S.
              • May 31, 1988
              • 1902
              Dave,
              Don't discard or lose this clip since I don't believe you will a find new or repro one easily or at all. When I did my '69, no-one had this clip. Maybe things have changed since then. Just get some EvapoRust and soak it until the rust is gone and have it replated when you do all the other fasteners.
              Jeff
              • Paul S.
                • April 6, 2010
                • 148
                Huh? That clip is readily available (pick your source) from Long Island Corvette, CSSB and others. Is there something I'm missing here?
                • Jeffrey S.
                  • May 31, 1988
                  • 1902
                  Paul,
                  Years ago when I did my car this was not available. I'm glad that it now is. Thanks for calling that out.
                  Jeff
                    • 43287
                    Dave------
                    Yes, sandblasting will clean it up. The only problem will be that while all the rust will be removed, about half the metal that was originally there is already gone. Not a good thing for a frame.
