71 Dim Headlight - NCRS Discussion Boards
71 Dim Headlight
  • Peter B.
    • July 31, 2000
    • 155
    71 Dim Headlight
    Hi Everyone - I have one headlight (low beam) that is very dim. Is it the light or maybe a connection? Thanks
    • 15625
    Re: 71 Dim Headlight
    Could be either. There are many connections. You could throw parts at it (replace with a known good bulb); or you could learn to check for voltage drop. This is a handy skill to learn. I guess it depends on whether you are into automotive repair for the long haul, or if this is a one time thing. Try googling "voltage drop" and see if you want to take it on.
    • Dennis C.
      • June 30, 2002
      • 884
      [QUOTE=Peter Bouza (34477);670961]Hi Everyone - I have one headlight (low beam) that is very dim. Is it the light or maybe a connection? Thanks[/
      Pete,
      Check both your ground connection and the connections to the back of the headlights. Make sure they are clean and tight.
      Dennis
      • Kurt G.
        • April 30, 2005
        • 343
        And to add to Dennis' comment, add some dielectric grease to the bulb contacts to help prevent further corrosion.
        Kurt Geis
        Chairman, Midway USA Chapter
        Targa Blue 1972, Top Flight and Duntov Award, 2014
        Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
        Arctic White 2013 60th Anniv Special Edition Conv.
        • Randy C.
          • March 1, 1985
          • 154
          One time when I reconnected my low beam T3 bulb, one of the prongs on the bulb didn't make it into the socket and it put out a real low level light. Once I figured out what I did, the light worked fine. Randy C.
