L 89 GM Rod and Main Bearings? - NCRS Discussion Boards
  • Steve W.
    • March 1, 2002
    • 78
    anyone know the GM part numbers for the Rod and Main Bearings, are they ok to use (any known issues with NOS originals?) Thanks, Steve
  • Dick W.
    • 10483
    Re: L 89 GM Rod and Main Bearings?
    I believe the originals were Moraine 400 tri metal bearings, the best on the market at that time. I would not be afraid to use them.
    Dick Whittington
      • 43290
      Dick------
      The original big block bearings were Moraine 400. However, they were not tri-metal. They were premium aluminum.
      Current GM bearings are also premium aluminum. However, they are manufactured by Federal Mogul. If one purchases the current GM bearings, they will be F-M in a GM box. You can get the same bearings in F-M packaging if you get their "AP" series bearings (much harder to find). From F-M,, they are available in sets; from GM only individual bearings.
      By the way, I am definitely NOT a guy that believe that all OEM parts are the same as aftermarket if they're manufactured by the same company. However, in the case of these bearings, I believe they are the same.
      By the way, I'm also a big believer in using premium aluminum rod and main bearings for street big blocks and small blocks, too.
