67 Cluster Removal - 1 Problem - NCRS Discussion Boards
+ More Options
Posts
  • Ron N.
    • August 18, 2008
    • 243
    C2_Dash_Cluster pt1.pdf
    I finally started to remove the cluster that has never been out of my original 67 using John Hinckleey's instructions (attached) that I found on Corvette Forum. I'm at the point where all knobs, switched, bezels, housings, etc have been dis-connected & removed except the oil line. I can't get the connection line bolt off. Mine is 5/16" vs 3/8" in the instructions (maybe on other C2's). The problem is that it's seated in recessed portion of the rear cover. A flat wrench slips off the nut and I'm concerned I'm rounding it (looks like brass).
    Tried liquid wrench, vice grip, several pliers even making a tool to fit.
    Any suggestions would be heplfull.
  • Ralph E.
    • February 1, 2002
    • 905
    Re: 67 Cluster Removal - 1 Problem
    Ron, you might try removing the line from the block and pulling the cluster out enough to get a wrench on it or even pull out the cluster all the way. Then once the cluster is on your bench you can untighten the nut and remove the line.
    • Edward J.
      • September 15, 2008
      • 6960
      I have done it like Ralph says and it makes it easier, I also undo the Tach. cable at Distributor.
      • Ralph E.
        • February 1, 2002
        • 905
        Ron,
        Did you get the cluster removed?
        • Paul J.
          • September 9, 2008
          • 2091
          Same here. Ron, if things ain't work'n right look at it from the other side.
          Paul
          • Ron N.
            • August 18, 2008
            • 243
            Thanks for the tip Ralph. I took you suggestion and disconnected the oil line from the block. It worked fine but I had other things to do so didn't finish the job. I'll get back into it tomorrow and with no other problems I should have it out tomorrow.
            I'll send another reply when I get it out.
            Thanks to all who replied.
            • Ron N.
              • August 18, 2008
              • 243
              The cluster is out and the way to the restorer.
              Thanks to all for the help.
              Ron
              • Robert K.
                • June 30, 2001
                • 212
                Ron,
                what was the problem on the back of the cluster (connection), or was there one. Perhaps the space was just too tight..
                • Ron N.
                  • August 18, 2008
                  • 243
                  My problem was that I could not get the oil pressure line off. The connection had a 5/16 (some have 3/8) brass bolt head. It seats in a recessed area on the back of the cluster that makes it hard to flatten the wrench to get a good grip. I could not get a lock wrench in the space. After trying several tools I rounded the bolt.
                  I took Ralph suggestion - disconnected the line from the block, pulled it through the firewall and when I got the cluster out used a lock wrench to get the bolt off.
                  Ron
