C1 (1958) Heater Copper 90 Degree Elbow - NCRS Discussion Boards
  • Justin B.
    • March 1, 1996
    • 478
    The ends of the 90 degree copper elbow are different diameters. Can anyone tell me which diameter goes where? Thanks!
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11345
    Re: C1 (1958) Heater Copper 90 Degree Elbow
    5/8" end to a short hose to the heater core, 3/4" end to the 3/4" hose to the water pump. This hose goes through the firewall into the elbow with the clamp inside the firewall. There should be a grommet for the 3/4" hose in the firewall, but reproduction ribbed hoses are too large wall thickness so you may not be able to use the grommet.
    • Dan D.
      • November 5, 2008
      • 1323
      Affirmative with the hose wall thickness and not fitting through the grommet. But all I did is remove some of the rubber from the grommet ID. Used a grinding bit in an electric drill - did the trick. Did not touch the fiberglass. The hose OD is not a lot larger. It does not take much to make it fit. -Dan-
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11345
        Dan, I was thinking of doing that to my grommet to but my ribbed (no GM stencil type)hoses from CC fit tightly through the hole in the firewall. I don't think it'd work for this one.
        Rich
