Carb Resto - NCRS Discussion Boards
Carb Resto
  • Mike W.
    • November 1, 1990
    • 71
    Carb Resto
    I'm looking for someone to rebuild/restore the Holley on my 71 LT1. I remember seeing an individuals name on one of the posts. Does anyone have contact information on him? Thanks
  • Ron W.
    Infrequent User
    • April 30, 1977
    • 25
    Re: Carb Resto
    You're probably looking for Bob Kunz
    314-845-2566
    11040 Lin Valle Drive St Louis MO 63123
    Holley also offers restoration services. Just check their website for details.
    • Mike W.
      • November 1, 1990
      • 71
      Re: Carb Resto
      Thanks Ron
      • Ron W.
        Infrequent User
        • April 30, 1977
        • 25
        Re: Carb Resto
        Mike,
        Correction on that phone number.
        New number is 314-406-6971
        Website: http://www.kunzauto.com/
        They have an ad in the latest Driveline.
        Ron
        • Terry L.
          • August 13, 2007
          • 99
          Re: Carb Resto
          Here is another option.
          Vintage Musclecar Parts
          306 Lang Ct
          Union, OH 45322
          937-836-5927
          I used them for my holly overhaul and was very pleased with their approach and quality of work.
          • Bill W.
            • March 1, 1980
            • 2000
            Re: Carb Resto
            Mike I have used Kunz on Holleys & Q jets and have been very happy .
            • Bill C.
              • May 31, 1989
              • 424
              Re: Carb Resto
              Phil Cancilla at Custom Rebuilt Carbs in NJ just did a 71 LT-1 carb for me, very pleased,and many others.
              • Edward L.
                • 278
                Re: Carb Resto
                If you want the carbs done in a matter of weeks rather than months, go with Phil Cancilla. He will be at Carlisle, Spaces 29-30.
                • William F.
                  • June 9, 2009
                  • 1364
                  Re: Carb Resto
                  A few caveats. Used Eric Jackson at vintage muscle car parts for a 3810 on a 300 hp '67. He was very helpful, but put wrong jets(too big)(he corrected this at no charge) but after car kept running rich, discovered he'd used 2 gaskets on power valve causing internal leak.Have heard good things from others, but had these problems on mine. Have heard Jerry McNeish does beautiful work if you can get him.
                  • William F.
                    • June 9, 2009
                    • 1364
                    Re: Carb Resto
                    Had an e-mail from Eric Jackson, Vintage muscle car parts. Said appearance of 2 powervalve gaskets instead of one was due to gasket separating when power valve was removed. Maybe,- Eric does a lot of carbs- but two pieces sure looked thick for one gasket. At any rate, problem was solved with new power valve/gasket tightened to specs. Like I said, Eric is helpful and conscientious and lot of good references for him on tech forum and sure he would have corrected whatever if I had called him and sent it back to him, but not wanting another sending back and forth, buddy and I replaced power valve and new gasket .
                    • Keith B.
                      • March 7, 2008
                      • 928
                      Re: Carb Resto
                      he did the carb on my Chevelle very nice work. bolted it on and did not have to touch anything
