C1 -Clutch fan vs standard fan - NCRS Discussion Boards
  • Philip P.
    • February 28, 2011
    • 558
    How much better is a clutch fan over a standard four blade fan? I was asked this question and really did not have a good answer.
    Phil
  • Tom B.
    • March 1, 1978
    • 720
    Re: C1 -Clutch fan vs standard fan
    A standard fan spins all the time constantly moving air through the radiator. You can't get any better than that for cooling. If I remember correctly the idea behind a clutch fan is that if not needed the clutch releases allowing the shaft to spin freely inside the hub thus eliminating the drag and loss of horsepower and performance on the engine caused from spinning the fan all the time. It was a performance thing more than a cooling thing.
    Tom
    • Philip P.
      • February 28, 2011
      • 558
      Tom.
      I actually never looked at it that way, that sure makes sense to me on the cooling. I knew of the performance side but I guess I was always under the impression the cooling would be better also. Do you know if the 5 blade clutch fan without the clutch is more efficient than the 4 blade? I have seen the clutch eliminator available but wonder if it is worth the effort.
      Phil
      • Brad K.
        • August 31, 1990
        • 414
        Try reading John Hinckley's article "Beating the Heat" in the latest "Restorer" magazine. It goes into detail about why a flex bladed fan may not be the right choice.
        • Jim L.
          • September 30, 1979
          • 1808
          I've converted my bride's '59 and my '60 from 4 blade fans to 5 blade clutch fans.
          The immediately noticeable difference was a significant reduction in underhood noise. Even if there were no other benefit, the noise reduction alone would be worth the effort and cost to do the conversion.
          Jim
          • Tom B.
            • March 1, 1978
            • 720
            That makes sense. I would think that a 5 blade fan would move more air also. I think I'll go read John's article. He is a wealth of information.
            Tom
            • Bill M.
              • April 1, 1977
              • 1386
              From Corvette News Vol 3 No 4: "Corvette's new optional temperature-controlled viscous fan drive increases power, cuts down on fan noise, and saves gasoline."
              No mention of improved cooling for the fan.
              But the same issue announces the aluminum radiator for "increased cooling reserve" and "the special cam engines run sweet and cool under the severest high-speed operation."
              • Philip P.
                • February 28, 2011
                • 558
                Does anyone know the specifications for the 4 and 5 bladed fans?
                Phil
                • Loren S.
                  • November 1, 2002
                  • 172
                  Jim
                  Did you also have to change out the fan shroud on the 59 to the 60-62 three piece job?
                  • Jim L.
                    • 1808
                    No. The change was no more involved than unbolting the 4 blade fan (and spacer, if I remember correctly) and bolting on the new fan and thermo clutch.
