1965 Corvette 4 speed - NCRS Discussion Boards
  • Owen G.
    Infrequent User
    • June 7, 2011
    • 18
    When up shifting or down shifting the back end of the car gets 'loose". Tires have correct pressures. Could it be something has come loose with one of the half shafts?
  • Loren L.
    • April 30, 1976
    • 4104
    Re: 1965 Corvette 4 speed
    Check the mountings on the nose of the differential.
    • Michael W.
      • April 1, 1997
      • 4290
      Missing trailing arm shims or bad bushings.
      • Jim T.
        • March 1, 1993
        • 5351
        Half shaft inspection is easy to do, are you unable to check yours?
        • Owen G.
          Infrequent User
          • June 7, 2011
          • 18
          Loren,
          Thank you for the information.
          • Owen G.
            Infrequent User
            • June 7, 2011
            • 18
            Michael,
            • Owen G.
              Infrequent User
              • June 7, 2011
              • 18
              Jim,
              Upon inspection the shafts are tight with nothing obviously loose. Thanks for the information
              • Joel A.
                • September 30, 1997
                • 213
                +1 on the trailing arm shims/bushings. Could also be the strut rod bushings gone wild.
                Joel Adams
                1974 Coupe
                1985 Coupe
                "I know the voices aren't real...but sometimes they have some really kewl ideas...."
                • Stephen L.
                  • May 31, 1984
                  • 3156
                  I had a similar problem on my 67. The rear of the car would give a little "wiggle" when shifting. After replacing everything in the rear suspension (frame off) it still did it. John Hinckley suggested that I drive some tight figure 8's in a parking lot to "free up" the positraction clutches. Problem solved. The bottom line was "lack of use" of the car. You might have the same problem.
                  • Jim T.
                    • March 1, 1993
                    • 5351
                    Owen as mentioned by another poster (Stephen L. ) using tight figure 8's to solve his problem, another maintenance area is changing your 65's rear end lubricant and installing the required supplement with the change available from GM for positraction rear ends. Your 65 may not have positraction, this was an option in 65-69 and earlier Corvettes. GM's rear end lubricant part #1052271 and GM's limited slip differential lubrication additive is #1052358.
                    • Owen G.
                      Infrequent User
                      • June 7, 2011
                      • 18
                      Stephen,
                      I have just climbed out from under and could not see anything obviously loose or missing. However, this vette does not have positraction, but, it does sit for long periods of time. Thanks for the suggestion
