Current perspective on 65 steering box finish - NCRS Discussion Boards
  • Steve A.
    • June 27, 2011
    • 15
    I have researched the forum and found a thread indicating that the current TIM/JG is in revision and the steering box appears to have been painted black as an assembly from the saginaw plant and delivered to st louis black.
    I have seen a box on a supplier site painted black except for the top cap which was natural with black phosphate bolts.
    I am at the point of my restoration that I am getting ready to install the box. Would like to get it properly finished. Current JG says either natural of black (I assume that was because earlier thought was blackout painting made them black)
    Is there any perspective that the top "check lube" plate is also painted black? I have the correct bolts but I cleaned the phosphate off them, seems silly to re-phosphate if I end up painting the cap and bolts black.
    Any insights?
  • Michael H.
    • January 29, 2008
    • 7477
    Re: Current perspective on 65 steering box finish
    Steve,
    I think the JG's for all 63-67's at one time called for a natural unpainted steering gear. The thinking has changed over the years though and now most agree that the entire gear assembly including the cover and flexible coupler were coated in black before leaving the Saginaw plant.
    • Tony S.
      NCRS Vice President, Director Region VII & 10
      • April 30, 1981
      • 993
      Steve, best to follow Michael's advice. That's where the research has taken us. Just DO NOT put paint daubs OVER the black paint. It's an instant deduct. Remember that the forward pinch bolt in the coupler was in place when the assembly was painted black. The rear pinch bolt is black phosphate--not painted black. Good luck. Tony
      Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
      Original member of the Kansas City Chapter, est'd 07/11/1982.
      Member: 1965 and 1966 National Judging Teams
      Judging Chairman--Kansas City Chapter.
      Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
      • Brian K.
        • May 31, 2004
        • 358
        Would the N96 steering coupler be painted, since it was a low production number?
        • Jim D.
          • 2885
          Yes it would.
          • Tony S.
            • April 30, 1981
            • 993
            That's N36, and as Jim Durham posted, yes it is painted.
            • Steve A.
              • June 27, 2011
              • 15
              Thanks all. Tony, were the shafts for the coupler and pitman arms also painted? My understanding is that the pitman arm was installed after and was natural forging finish. Also, I assume that the rear bolt was not painted because it was only added during assembly and not there during painting?
              • Tony S.
                • April 30, 1981
                • 993
                Steve, the pitman arm was added at St. Louis so it would not have been installed at Saginaw when the steering box assembly was painted black. Some pitman arms are natural (power steering) and some are painted black (non-power steering). The rear pinch bolt is not painted because it was added at St. Louis. The front pinch bolt was added at Saginaw before black paint.
                Good luck.
                Tony
