66 Leaf Spring Liners - NCRS Discussion Boards
  • Nick M.
    • January 1, 2005
    • 58
    Quick Question: I am placing an order with Long Island Corvette and one of the items I am looking at purchasing is a set of Leaf Spring Liners. How do these judge? I know that I have read that Quanta Liners judge well, but hate to place an additional order for just these. Thanks
  • Gene M.
    • April 1, 1985
    • 4232
    Re: 66 Leaf Spring Liners
    Nick,
    Comparing the profile of the repops to the original the originals have heavier longer legs that trap the spring leaf. Would they judge any different......... the judge would be unreasonable to make deducts since the difference is not noteable unless the two are side by side...... in my opinion.
    • Mike E.
      • June 24, 2012
      • 920
      Nick,
      I just received a set of liners from LIC. Here are a couple of shots of them beside an original. They are pretty close, not perfect but close. On my original one leg is different width. I have no idea why? The inside width is virtually identical between the repop and original. They seem to fit the spring fine.
      Mike
      • Larry M.
        • January 1, 1992
        • 2700
        Originally posted by Mike Eby (55078)
        Nick,
        Mike
        Based on what I can see in these pictures, it appears that the LICS liners are the same as Quanta liners. They probably sourced them directly from Quanta.
        Larry
        • Jeffrey S.
          • May 31, 1988
          • 1890
          Eaton Detroit will sell their liners by the foot. I bought theirs and compared it to liners from the original spring I was restoring. I could not tell the difference in any respect including thickness and configuration of the "I" beam dimensions. Theirs will come in one long length that you will need to cut and you will have to put in the indentation cuts at the middle of each leaf. You will also need to put in the hole for the bolt. I made a template which was clamped to each section using the bolt hole to get the location and cut each with a sharp knife to the template and they came out perfect.
          Jeff
          • Nick M.
            • January 1, 2005
            • 58
            Thank you all for your Reply's. It is very much appreciated
            • Ralph E.
              • February 1, 2002
              • 905
              So Mike, what have you decided to do.
              Stay with LIC or change to Quanta or Eaton?
              • Ralph E.
                • February 1, 2002
                • 905
                • Jeremy R.
                  • May 23, 2012
                  • 137
                  I was told by LIC that Quanta sources their liners from them.
                  • Kim C.
                    Quanta buys the liners from Long Island.
                    • Nick M.
                      • January 1, 2005
                      • 58
                      I have ordered my liners through LIC.Thanks
                      • Mike E.
                        • June 24, 2012
                        • 920
                        Ralph, I stuck with LIC parts.
                        I put my spring back together tonight, with the holes and the slots cut it only took a few minutes, I still have to grind the center bolt to the correct length. Here are some before after shots of the spring. Note: I think this an F40 spring which is not correct for my car. The ride height was right on the car prior to the restoration so I just live with it for now. If I decide to have my car judges I'll have to change it. IMO the gray paint that LIC sells is a bit too light. Photo #3 shows what was left of the original paint.
                        Does anyone know what the center bolt should be torqued to?
                        Mike
