What is the correct configuration of fasteners for attaching (a) clutch fan to water pump hub and for (b) fan to clutch? Studs or bolts? Bolt markings? Etc. Thanks much,Charlie
Correct '62 fan clutch & fan fasteners
Tags: None
Re: Correct '62 fan clutch & fan fasteners
They are Grade 8 bolts. 5/16-24 x 3/4" with lock washers. Don't know what the head marking is for the manufacturer. Paragon sells three different kinds. I thought they were black, but can't be sure. You do want a Grade 8 bolt in that application.- Top
One more thing. Don't forget the spacer or reinforcement that goes in between the nose of the water pump and the pulley. See the vendor catalogs for a picture of what I mean. Paragon has it as their part number 846.- Top
