By Pass clamps for 1967 big block - NCRS Discussion Boards
  • Alex A.
    • February 6, 2013
    • 42
    I have a 1967 427/390 and my water pump by pass hose has 2 clamps. They are marked with "Wittek" 37. Is this correct? I have heard that Wittek 10 or 39 is the correct clamp. Does anyone have any more information?
    Alex
  • Michael G.
    • January 1, 1997
    • 1251
    Re: By Pass clamps for 1967 big block
    Alex,
    Have you sourced the judging manual?
    • Alex A.
      • February 6, 2013
      • 42
      Michael,
      I actually have checked the manual and it only talks about the Wittek screw clamps. They are supposed to be dated by quarter and year. The only problem is I have found those exact clamps with either a number 10,37 or 39 on them.
      • Ronald L.
        • October 18, 2009
        • 3248
        10 are on early BB
        • Alex A.
          • February 6, 2013
          • 42
          Do you happen to know what 37 or 39 represent? I have a Jan 5th 1967 big block. Also, are the clamps supposed to have dates on them? Thank you.
          • Ara G.
            • January 31, 2008
            • 1108
            Alex, the upper and lower radiator hose clamps are the ones that are dated, along with other various clamps for air tubes, etc (all tower clamps - unlike the bypass clamps) but the bypass hose clamps do not have dates on them. Regards. ARA
            • Alex A.
              • February 6, 2013
              • 42
              Thank you. Do you happen to know what the number 10, 37 or 39 signifies on the by pass clamps? I know they all say Wittek but I can't seem to find out what the numbers are all about. Mine currently have Wittek 37 on them.
              • Ara G.
                • January 31, 2008
                • 1108
                Alex, from my experience 67 BB should have #10's on the bypass hose. I believe 39's were service replacements made to replace the 10's. ARA.
                  • 15632
                  I believe those numbers represent the diameter of the hose the clamp is designed for in 1/16 of an inch. So 10 would be 10/16 or for a 5/8-inch diameter hose.
                  • Alex A.
                    • February 6, 2013
                    • 42
                    Ara,
                    Richard Fortier has also told me the same thing. The #10's are original to the car and the #39 is the correct replacement. The interesting thing is I have #37. Thank you
                    • Ara G.
                      • January 31, 2008
                      • 1108
                      Alex, I am not 100% positive but I think the Wittek 34 and Wittek 37 were clamps used on Ford products and not GM products
                      • Alex A.
                        • February 6, 2013
                        • 42
                        Wow. Thank you for all the information. I have an opportunity to purchase 2 #10's. Do the numbers mean anything besides just a number on a clamp? Thank you
                        • Ara G.
                          • January 31, 2008
                          • 1108
                          Alex, like Terry said in this post it may represent the diameter of the hose fitting....I don't know for sure, but Terry SURE knows his stuff....Put the #10's on your car and rest easy....they represent TFP in our eyes....Good luck...ARA
                          • Alex A.
                            • February 6, 2013
                            • 42
                            Ara,
                            I will. Thank you very mych for all your advice and input.
                            • Ara G.
                              • January 31, 2008
                              • 1108
                              Alex, Anytime...As a new member, you will find the NCRS members are the best and most knowledgeable out there. When I joined I couldn't believe how helpful they all are/were. Have fun with your car, and enjoy the ownership experience as well as the learning experience...
