54 coil performance - NCRS Discussion Boards
54 coil performance
  • Guy M.
    • November 1, 1993
    • 500
    54 coil performance
    Can a faulty coil make an engine run poorly? I was under the impression that it either it works or it doesnt. Thanks for the input!
  • William C.
    • May 31, 1975
    • 6037
    Re: 54 coil performane
    Generally speaking you are correct re the coil, what type of problems are you having?
    Bill Clupper #618
    • Guy M.
      • November 1, 1993
      • 500
      This is a fresh rebuild of everything. Just readjusted the valves and they are ok. All the usual stuff is new, plugs, cap points etc. with the ball on the pointer the rotor points to # one with the points open. Have 3.8 psi to the carbs. Engine stumbling around. I have the chasis rigged to run. The fuel bowls are full to within 1/8 inch of the divide inside. Fresh head gasket, no leaks. Compression is around 100, one is 90. Had the head rechecked for valve leakage, all ok. I cant believe its timing with the way its set up. New condfensor. The only thing I havnt replaced is the coil which is why Im asking the question. Maybe its running so rich its choking itself. The plugs are carbonned up pretty good. Im wondering if that can make it run so poorly. This thing should be purring. The carbs are freshly rebuilt. Whats left?? close to body drop and I would rather not work around the body. This has less than 2 hours running time on it. Im stumped
      • William C.
        • May 31, 1975
        • 6037
        Have you actually checked the timing with a light when someone is cranking the car?
        Bill Clupper #618
        • Rob M.
          NCRS IT Developer
          • January 1, 2004
          • 12729
          bad capacitor can also kill an engines performance (also new capacitors can be bad)...
          Rob.
          NCRS Software Developer
          • Guy M.
            • November 1, 1993
            • 500
            Ill go back and verify it again, Can the timing still be off that bad if its set up ncorrectly. I guess the distributer can be off a tooth and still run perhaps?
            • Chris S.
              • January 1, 2000
              • 1067
              these things run like sewing machines....
              something is wrong
              1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
              Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
              1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
              1957 Corvette - FI 3 sp - Black and Silver
              • Joseph S.
                National Judging Chairman
                • March 1, 1985
                • 864
                Buy a cheap auto parts store COIL! We have solved many poor running issues with new coils. If your spark is not strong enough it will never run properly.
                • Cathy S.
                  • August 31, 2003
                  • 293
                  Try a napa coil. About $40 never an issue
