Water pump bolts/studs for 1967 427/390 - NCRS Discussion Boards
  • Alex A.
    • February 6, 2013
    • 42
    I have a 1967 427/390 convertible. Where should the stud on the water pump go? Mine is on the top hole on the drivers side. I believe it should be on the top hole on the passenger side. I also believe the outer threads should not be painted. Is that also correct?
    Thank you
    Alex
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: Water pump bolts/studs for 1967 427/390
    The bolt/stud is located on the upper right and the threads were masked (bare)
    • Graeme B.
      • October 23, 2007
      • 213
      Yep , passenger side for the A.I.R. pump adjuster bracket. Paint I do not know.
      • Alex A.
        • February 6, 2013
        • 42
        When you say the upper right I assume you are referencing the passenger side. Thank you very much for the help.
        • Alex A.
          • February 6, 2013
          • 42
          Thank you.
