Need new brakes, wheres the quality ones - NCRS Discussion Boards
  • Calvin C.
    • May 31, 2002
    • 240
    Who has good luck buying brakes. I need to put a new set of calipers and soft lines on a 69 driver. Any advice on who has a good product, some of the kits look good for price. I have heard stories of really poor rebuilds. Not sure if the brakes on car are original, I will keep them for a later resto if they are.
    thanks
    cal
  • Anthony S.
    • September 3, 2007
    • 108
    Re: Need new brakes, wheres the quality ones
    Cal - I bought my calipers, rotors, lines and pads from Lonestar Caliper three years ago for my 68 and have not encountered any problems.
    Tony
    There are two kinds of friends; the friend you call to bail you out of jail and the friend sitting next to you in the cell saying "Damn, that was great"!!!
    • Paul D.
      • January 1, 1988
      • 101
      I have also used Lonestarcaliper on several cars without any issues..............P..
      • Calvin C.
        • May 31, 2002
        • 240
        Are the new Delco's worth buying for a daily driver, Cal
        • Anthony S.
          • September 3, 2007
          • 108
          My philosophy is I’d rather spend the money for a quality product once than spend less for an inferior product that may fail and then you find the need to spend more $$$.
          • Calvin C.
            • May 31, 2002
            • 240
            So you like the brand new calipers that require no core charge.cal
            • Paul S.
              • April 6, 2010
              • 148
              Anthony's point is a good one--Lonestar does not charge a core deposit on new calipers and CSSB does (CSSB core charge is $220). Both Lonestar and CSSB charge core deposits on rebuilt calipers.
              Return shipping isn't cheap, to send your old cores back. It depends on distance, but you can estimate based on 50 pounds of shipping weight for 4 calipers. As for recommendations, I have a set of Lonestar's O ring calipers on mine and would recommend them unless your heart is set on black (like the originals) calipers, as Lonestar's are painted silver. The silver is nice because it is far easier to see seeping/dripping brake fluid on a silver painted caliper vs. shiny black (from CSSB).
              If you buy from Lonestar, you need to call them as their website is for wholesale only. They will sell/ship to retail consumers if you call and buy over the phone. Note too--if you want O ring calipers, telll Lonestar that specifically as they ship lip seal calipers by default.
              The only difference (than price and paint) I could tell from Lonestar and CSSB, is CSSB's rubber brake hoses seem a bit better (but then again, I couldn't get the CSSB caliper to brake hose connection to quit seeping brake fluid, which forced me to return theirs and start over with Lonestar--long story). If you go with CSSB, and you have problems getting the hose to caliper fittings to be dry and tight, you might try using a single washer instead of the two they recommend--I didn't do that on mine, as I did not have extra washers and by that time the hoses were on so tight (at CSSB's suggestion), I couldn't get the hose loose without cutting the hose and getting on it with an impact wrench. Lonestar ships their calipers with one washer and I was able to get both front calipers to seal, having to retighten one of them a second time after the initial post-installation test drive.
              • Kurt G.
                • April 30, 2005
                • 343
                Michigan Brake has good product. I had them do my calipers, o-ringed, several years ago. And they are painted black. All you have to do is clean the paint off the machined surfaces and the are ready for judging.
                Kurt Geis
                Chairman, Midway USA Chapter
                Targa Blue 1972, Top Flight and Duntov Award, 2014
                Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
                Arctic White 2013 60th Anniv Special Edition Conv.
                • Terry B.
                  • August 31, 1999
                  • 607
                  Kurt, Do you mean Muskegon Brake? http://www.muskegonbrake.com/ I'm shopping calipers too but would like Delco Calipers and correct for '68. Any chance of getting that with any of the above companies? I'm also concerned about painting Lone Star calipers black and then having a problem with them taking a return. Any advice? Lone Star's website has a problem too with their security when you try to register to get prices. Is that a red flag for them? Thanks, Terry
                  Terry Buchanan
                  Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
                  Corvettes Owned:
                  1977 Coupe
                  1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
                  2003 Electron Blue Coupe
                  2019 Torch Red Grand Sport Coupe
                  • Kurt G.
                    • April 30, 2005
                    • 343
                    Yea, Terry. Muskegon Brake. Hey, it's in Michigan isn't it. I'm an old fart and sometimes wonder who the guy in that window in the bathroom is.
                    Kurt Geis
                    • Paul S.
                      • April 6, 2010
                      • 148
                      I have the wheels on my 67, so I cannot see the casting numbers, but this much I do know. With both Lonestar and CSSB they are Delco and the casting numbers were the same for both vendors but they were not correct casting numbers for a 67. If memory serves I think they were 5473795 front and 5473806 rear. Why they both advertise as correct casting numbers, I do not know, as it appears they make no effort to match casting numbers to your year. With CSSB I was expecting correct #'s based on their website and catalog.
                      On Lonestar pricing, you have to register and I can see pricing on their site; to order (unless you're a business) you will need to call Lonestar. If you cannot see pricing, just call them. I don't consider that issue a red flag, when you look at it from the standpoint that their website is for wholesale only and they do sell at retail, if you call them.
