64 air conditioning - NCRS Discussion Boards
64 air conditioning
  • Mike M.
    • May 31, 1974
    • 8400
    64 air conditioning
    am in need of the absolute vacuum regulator that fastens to the suction throttling valve. my original regulator sprung a leak. hate to tear it apart and renew any o-rings/ seals that may be (or rather almost certainly are) inside the critter. anybody have a source? anybody taken the regulator apart successfully( its got tabs that fasten it together and i fear the tabs will break off on disassembly) . would the c-60 system function at constant sea level if i run the ac without the regulator? thanks guys, mike
  • Harry S.
    • July 31, 2002
    • 5330
    Re: 64 air conditioning
    Mike, try: http://www.classicautoair.com/ They do have an inventory of parts and they repair/restore 63 and up AC systems.
    • Jim T.
      • March 1, 1993
      • 5351
      Mike looking at my 1964 Corvette supplement service manual of the picture of the absolute vacuum regulator I do not see o-rings. A couple heavy darken places could be seals. There was a regulator for sale on E-Bay that ended in June. It said it was rebuilt and sold for $90.XX. Wonder where the parts came from? Was the absolute vacuum regulator only for Corvettes?
      • Don H.
        • December 1, 1981
        • 1491
        Mike, I second the Classic Auto Air. I had them rebuild my STV and it works great. Don H.
        • Randy S.
          • January 1, 2003
          • 586
          Mike
          Yes it will. Mine (66) has a vacuum leak somewhere so I have the vacuum line connected for appearance but it is plugged internally. From my service manual "The absolute pressure regulator device on the STV used with Corvette Air Conditioning System acts to maintain a relatively constant pressure (regardless of altitude) in the sealed adjustment spring chamber of the STV thus minimizing the effect of atmospheric pressures in the operation of the valve.
          Randy
